Exhaust manifolds
Polo62
6:53 PM
Woodland ms
Will a 68 fury hp manifolds from a 383hp fit on a 440 into a 70 charger
The short answer is yes they will fit.
But...... if you are trying to match up to allready formed B body exhaust header down pipes the mounting angle may be off as far as matching the pipe and manifold outlet.
The pass side is the same. The drivers side outlet is further ahead on the cbody manifold
Driver side c-body is quit a bit different. Doable but will need a driver side pipe made.
