62 Dart Convertible
I restored my 3258/3259 combination a while ago and the jets/step-up rods were badly pitted with corrosion and needed replacing. I found they were unavailable, so I did the calculations to find the closest equivalent combinations in the Edelbrock range. I'm yet to fit an AFR meter to fine tune but on the road/plug reading it seems OK..
Is the staggering of the jetting between rear and front carbs done purely to correct uneven distribution of the manifold, to suit the progressive throttle linkage or because there are emulsifiers, venturi or air bleed differences between 3258 and 3259? I wonder if I will require primary jetting changes with my planned addition of a PCV valve?
Those with real experience, please chime in.
