Charlie Brown
- 2:23 PM
- May 23, 2021
- Vars, Ontario, Canada
Changed the oil pan on my 426W for a max wedge unit. Previous pan / crank seal was leak free. After the pan switch, there was a small leak. Leak then got larger to the point that it needed attention. I suspected the oil pan gasket. After a gasket change and a visual check, I noticed that where the oil pan bolts thread into the factory rear main seal retainer, that one of the nubs / capped end which receives the pan bolt is broken through. I suspect that the oil leak issue I was having is related to this. I probably used a bolt that was a little to long and "popped" the end of the cap. Is it possible to use a specific sealant on the bolt threads to stop the leak?
