fan shroud
70bee
10:18 AM
texas
are all 70 body fan shrouds (26 inch rad) the same you know small block & big block found small block at reasonable price just need to know im running a 440 thanks
If it is original check to see if the notch for the rad. hose is on the correct side. If I remember correctly the later replacement ones have it on both sides wit a block off plate that can be used on either side.
the guy says there are no notches he says it is off a 1970 satty with a 318 my question will it work on my gtx with a 440 thanks
Yes it is the same shroud and Part # 2998326, fits 318* 383* 426 hemi 440* w/26" core * w/ac
77 doba?
will the same part number fit my 77 cordoba, 400 engine?
