Macdon221
Good Day All,
In need of some guidance.
As the title says....been fighting with a 440 to get it right. It's a newly built engine in the last year or so. A little bit of porting, comp cam #21-223-4. Nothing too crazy. Stock Heads.
The engine ran good, not perfect...a stumble off the line but that's about it. Idled ok after warm. Choke was not set up. It makes tons and tons of power. Stock intake. Stock original carter avs carb. Also had original dist with a pertronix pick up with the standard coil....extra wire ran to the ballast resistor. Started and idled ok.
I like things back to stock...just my thing....so I replaces the carb with a newly restored correct CARTER AVS carb. Same carb just restored. Same jetting. Stock 101 primaries and 95 secondary's. Spring set installed allows the to sink on idle and pop up when throttle is blipped.
I removed the correct original numbered dist that was installed, which is the original one to the car, and installed a correct numbered newly restored dist with points and condenser. No pertronix pick up.
Choke all working fine. Car will start, warm up no issue. Smooth idle. Idles done to about 650-750 in gear no issse. Can get lower if needed.
Dist has been set to about 15 initial. Have FBO limiter plate installed to ensure all in no more than 34. Reeving up and checking the timing confirms this. Dwell set to 30...checked with feeler gauges for the ballpark and with a dwell meter.
Removing the vacuum advance at idle makes no difference to the timing....so at idle the vacuum advance is not influencing the timing.
Now here is my nemesis....start, warm up, drive, all good. Tons of power through all ranges. Zero hesitation from off idle. Very responsive. Gear shift points are good. Start, stop, idles good. BUT.....after about 15-20 mins of driving and the car heats up....the idle rises to about 1500. If wont go back down. The throttle is closed and back on the stop screw...same as where we started at. It also wanders a from back to 1000 and then back to about 1500. I have repeated this cycle 3 times now...let it cool...next day...same thing. Great at the start...but after a good warm up
the cars idle is again not correct.
So....I have changed the carb to another avs carb while car still warm...restart...same. Changed the carb base gasket multiple times, 4 hole, open ...same. I have switched the coil when warm to cool coil....same. I have capped all vacuum sources while warm....choke diaphragm, pvc port, vacuum advance port, brake booster port on engine, and vacuum headlight (69 charger) port....no change.
I have tried to find an carb or intake manifold leak with water, and propane....no luck.
Where from here?
1. Should I go back to the original dist with the pick up? Try a new condenser? New points?
2. Ballast resistor?
3. Continue to look for an intake leak and how?
I really appreciate all your guys/gals help. I love it when my car is working perfectly....and I need help for this one.
macdon221
the cars idle is again not correct.So....I have changed the carb to another avs carb while car still warm...restart...same. Changed the carb base gasket multiple times, 4 hole, open ...same. I have switched the coil when warm to cool coil....same. I have capped all vacuum sources while warm....choke diaphragm, pvc port, vacuum advance port, brake booster port on engine, and vacuum headlight (69 charger) port....no change.
Where from here?
macdon221
