I have a question about heat resistant butyl mat that I will be installing on my inside firewall.
All the appliances have been removed from the firewall to install the butyl mat sections.
backside of firewall has been thoroughly cleaned
Because of the 80mil thickest of mat......
the butyl is soft so it should squish down very thin.
will I have to cut the mat so it is not between the master cylinder, brake pedal assembly and the fire wall?
I understand that the firewall holes will have to be cut..
will the clearance be too thick if I place it between the MC, brake-clutch assembly and firewall?
Your input is needed..
A thank you to all who participate....
