Firewall wire location
popslavaz
3:48 AM
Channahon IL.
Dash all done,just need to know the firewall entry location for the dash reverse light wire that plugs into the bulkhead harness.Thanks POPS
Isn't that two wires in the bulkhead disconnect???? I think the very top left two, top plug???? You should double check since I'm going from memory
No the black wire from the dash mounted REVERSE amber light that has to pass through the firewall to plug into the pig tail that hangs from the engine side of the bulk head .Just need to know where the wire passes through thr firewall. Thanks
1969... don't know if 71 is the same and you didn't state a year either.
Look at your cars wiring diagram, it spells out the bulkhead pin/location numbers.
Thanks QuickBpBp,it's the small factory indent marker just above the bulkhead like you said. POPS
