Burt Byers
I may be the only human on Earth that didn't know this. But if I educate one person pecking this out it will be worth it. I bought a Max Wedge recently. It's been a drag car since late 64 or 65. It had lots of braided fuel line on it. My son and I run a Modified Four Wheel truck and have been competing in this sport for 25+ years. It also has quite a bit of braided hose on it. Some of it is probably 20+ years old. However, the only thing that runs though the hose on the truck is either alcohol or oil. I was starting the car a few days after I got it. No air cleaners. Hood is closed. It back fired through the right side carb when I cranked it for the last time. I thought I saw something coming though the hood gap on the right hand side. I got out, opened the hood and saw flames two feet tall. The flames were coming from the braided fuel line. Put it out with a couple of fire extinguishers. Talked to the guy that did the last build on the car eleven years ago. He put the braided line on. I believe the difference on the truck that has some braided line on it and the car is the car has had gasoline run through it and the truck only alcohol. So my opinion is the gas has something that degrades the inside of the braided line. Alcohol doesn't. This car was setting in a building with nine other classic cars. It was insured, goes to the body shop Monday. I guess the moral of the story is "Braided line doesn't last forever so if you have some on your car that's more that a couple years old, change it out". Sorry this turned out to be such a long post. Burt
ethanol in it EATS the older style "rubber" fuel lines and it does so fairly quickly.
