front suspention
67 gtx cov
2:26 PM
spring city pa
67 gtx manuel steering took it down the road and it was very sloppy when the road dips down on the right it tries to turn right same on left all the joints are good thanks:headbang::headbang:
What kind of tires are you running on it and what parts are old? You can have new ball joints but if all the bushings suck, then it can act like that....and it's pretty unusual for a GTX to have manual steering....
cranky the uppers have been replaced moog offset front tires are ta s the steering is factory
yeh sounds like needs an alignment done and maybe the steering box needs an overhaul or was that done already?
1 of my cars used to do that then found out the shocks were stuffed and it was only pretty much relying on the torsion bars
Even with no front shocks, if the front end is good and the alignment is right, it should still drive straight....but without shocks at all, the car will just bound up and down with every little dip in the road and isn't a fun ride. Or maybe it was :D Yeah, I've done that just to see how it would act lol
