- 11:28 PM
- Mar 28, 2014
- South Louisiana
So I have a WIX metal fuel filter at the end of the hard line that comes from the gas tank, then the mechanical fuel pump, which is the Carter M6903, and then a metal reusable 40 micron low restriction inline filter that is part of the Promax lower fuel line, and then the 3 lines to the carbs.
I was just reading the 6 pack Engines book by Larry Shepard and he suggests the fuel filter go between the pump and carbs. I'm pretty sure the WIX filter at the end of the hard line is the stock filter location.
Either way I'm covered, but feedback is welcome.
Next is the fuel vapor separator. When I installed the Promax lines, I had to plug the vapor separator return line to the tank because I couldn't integrate it with the new lines. The vapor separator has been removed from the system.
Is that ok?
Is that ok?
