Ok ok. here is what I did. Got a brass female thread to male thread 90 degree fitting. Drilled a hole in the top of the filler neck between the cap fitting and the brace hold down strap for the neck. Then tapped the hole with an 1/8 water pipe thread. Did this on top of the filler neck. Put a two inch nipple on it and put 5/16" fuel hose on and ran it to the passenger side to clear the exhaust pipe. Turned it down and out under the bumper. It was just a little wet after a test drive but not leaking out on the floor like the other vent's where doing. Car runs much better. Looking into the roll over vent valve that Holley sell. This could be option to go with on the end of the line. Yes will have to turn it up in stead of down. It is a work in progress. LOL.
