beanhead
Easily Offensive
Similar to the vapor separator setup the factory used huh. Adding a 1/4" return line is something I've wanted to do, since my sender has the nipple for it. Oh well maybe THIS winter..
Once my speed demon 850 double-pumper equipped 440 warms to operating temp, it stays where I have it set for the different throttle areas, and it's hot here. Mech pump with no return line. Might be more internet myths....more of that than truth out there nowadays unfortunately..My understanding is a return line also keeps the afr from fluctuating with temp, therefore it runs better. Basically you set everything, mixture, timing, etc, close the hood and drive it, it gets hot in traffic, afr goes haywire, runs crappy.
I'm sure that can be explained better.
Hey kern dog, I went to jegs web site and found a hand full of side outlet fittings for mounting a fuel gauge that you could put inline. Maybe put fitting in one side of y block, mount gauge, run lines to carb, cut in filter, presto-chango your all done. Well, maybe not that easy. But there are a lot of fitting options on jegs site. I hope it all works out for you!I fought this same battle, finally found a brass Y, but no place for a gauge.
The brass worked, but could easily leak if I took it apart and put back together, for whatever reason.
Tried to get creative, I had a dual inlet line with gauge port, but rubber hose in the middle, bought a new solid one but it leaked, bought another new solid one with a gauge port T but it was aluminum and leaked.
Looked for a speed shop, eventually found a race guy who gave me fittings.
Maybe just bad luck.
Once I went to AN fittings and ptfe, no more bs, went together super easy, comes apart and back together easy, fuel filter has AN fittings, everything is perfect.
Btw, my fuel filter is aluminum, so can't see gas in it, I used to like to see the gas too, but I never see it 100% of the time when in the driver's seat and if gas isn't in the carb it's easy to pop off the filter.
For the hard lines I had to buy line, a bender, flare tool kit, fittings, hose, filter, clamps, etc.
For AN I bought line, fittings, filter, line cutter.
Cost was probably close, but the AN saved time, went together once, and prevents bs in the future.
