Fuel/Oil pressure gauge question
chykov's76doba
3:04 AM
Lansdale Pennsylvania
I need to replace my dual fuel/oil pressure gauge in my 76 cordoba, will a similar gauge from a 71 to 74 charger work as a replacement? there are a number of them on ebay and they aren't as pricey as the 76-79 versions that would be an exact match for mine.
Any help is appreciated.
The dash frames all look to be the same there are 3 different type of instrument panels that use that frame it may work or not different mounting holes and wiring would be the problem you run into . I did manage to put a instrument panel from a 69 charger into a 69 coronet i got it to work but that was some of the problems i ran into with doing that .
Nope. Totally different instrument cluster. Actually the gauges are separate pieces. Look to 75-79, fury, road runner, charger and cordoba.
I have a full instrument cluster for a 75-79 if interested. Please PM.
