DC67
Does anyone recommend a mechanical pump from a brand / sources other than Carter that reliably delivers the lower 4-4.5 PSI ?
My 67 Charger is stock (see info. below) and it has never really run well. I've been chasing fuel problems and have replaced everything from the tank to the carburetor. It is fouling plugs, idles rough and I recently saw fuel varnish appearing on the sides of carburetor.
The carburetor (Carter 4326S) is completely clean with everything adjusted including the floats. The only issue is high fuel pressure: The Carter M6903 (High Performance) shows 6-6.5 PSI when running - so I installed the stock replacement pump (Carter M3672 rated at a lower 4-5.5 PSI) and it is now showing 9 PSI!
The service manual and other resources claim the Carter AFB is sensitive to fuel pressure and needs 4-4.5 PSI max. to prevent fuel from blowing past the needles.
Added Edit:
I'd like to find a pump that puts out the right pressure and avoid the modifications needed to install a fuel pressure regulator.
Any guidance appreciated!
Vehicle Background Info.:
Vehicle: 1967 Dodge Charger - 71 440ci motor
Carburetor: Stock Carter 4326S
Old Fuel Pump: Carter M6903 (Rated 6-7.5 PSI) -- Delivering 5-6.5 PSI
New Fuel Pump: Carter M3672 (Rated 4-5.5 PSI) -- Delivering 8-9 PSI
Main Fuel Line: New 3/8" Steel Line from Tank to Engine Bay (stock configuration)
Pump to Carb: New 5/16" Stainless Line (stock configuration)
Added Edit:
