fuel sending unit 70 charger 440
Frank1970
9:42 AM
New city ny
Hello, i am little confused on how to properly connect the gas tank vent line and 1/4 return line that goes to the separator? WHat i see now is the small port on the sending unit has the fuel cap vent line attached? Should that port be the 1/4 return line? If so where does the fuel cap vent line to to? I see many ports on the passenger side of the tank? THanks
The 1/4 inch at the sender is your return line. On the Charger your fill tube will have a 1/4 tube off it. That is your vent.
Thanks, where does that tube connect? It is currently connected to the fuel sender at 1/4 tube
Who ever connected it there should not work on cars. It just goes down through the trunk floor inside a grommet into the frame rail.
So I open up a can of worms thinking I had to replace the sender! I removed it already turns out my sender did not have a filter on it. Now how do you hold that gasket in place before tightening! Seems like if that gasket is off a bit major leak!
You should be able to use a small amount of sealer to hold the gasket in place.....and make sure the tank flange is flat all the way around. Found one that was slightly bent a couple of years ago on a 69 rr that I was working on and the owner couldn't get it to seal.
I tried putting in the new one, looks the same as the old one but the flange does not sit easily on the top, sounds like it’s hitting the bottom of the tank? Should it sit flush easily?
