Gas tank sending unit testing
Timmayy
3:15 AM
Tiverton RI
Since I'm cleaning up the gas tank in wifey's wagon I figured I'd also get a new ring and seal. Before I put it back together, how do I test it to make sure it works? I don't want to put it all back together and then the gas gauge doesn't work. I need to do it on my shop bench. Car is apart and has no power.
No power required. Just a volt ohm meter. Set it to ohms and test the resistance through the range of the float arm.
Ok, sending unit seems good. Had to clean it with some terminal cleaner because the gauge was bouncing all over the place. Around 65 -75 ohms empty and 12-16 full. Now I can repair the tank. Thanks all.
Just in case it doesn't work after being installed or works briefly and goes out. I will add my experience from 47 years ago or so. I had an old A-100 van that had a problem which I just described. It worked briefly and gradually didn't. It turned out the were two or 3 tiny pin holes around the indented middle of the copper float under the arm connection. They could barely be seen. I saw tiny bubbles when I immersed it in cleaning fluid after removing the third time. I never noticed the difference in weight at the time. The float would slowly take on gasoline after being installed. It might not have filled completely but enough to affect it's buoyancy. The newer ones probably are plastic! :D
Mine is plastic. I assume someone changed it before me.
