LowBikeMike
I would buy a diesel unit. What makes you think the NG source will still work and be consistent in a major event?
I placed them where I wanted then and purchased all the parts needed. Had a local electrician hook them up. Took about 4 hours and cost me 500 cash.
That's not Generac...that's 2021.Generac, if you have commercials for your product, have some in stock to sell. You just lost a customer.
Only Problem with Diesel is you have to have certified tank system in order to keep it filled. NG is also far cheaper for the time being than diesel but I get what your saying...cr8crshr/BillI would buy a diesel unit. What makes you think the NG source will still work and be consistent in a major event?
See my post about using heating oil...Only Problem with Diesel is you have to have certified tank system in order to keep it filled. NG is also far cheaper for the time being than diesel but I get what your saying...cr8crshr/Bill![]()
I did. Heating Oil??? Is that even being used any more???cr8crshr/BillSee my post about using heating oil...
There are basically three (3) major generator manufacturers/suppliers : kohler, Onan and Generac. I TOTALLY recommend GENERAC. I installed a 22 Kw unit, that operates on Natural Gas or Propane fuel (slectable) along with the necessary transfer switch, that automatically transfers from utility supply to generator supply during a utility outage. The generator supplies 100% of the power to operate my home including the A/C, electric stove, dryer, computers, refrigerator/freezer, lighting, etc, and can do continuously for 24-7 if needed. The transfer switch supplies all generator starting battery trickle charge functions. The generators programmable controller supplies all safety and operating system functions including voltage and over current functions......the system operates seamlessly. The total installed costs of all equipment, ancillary wiring, fuel gas piping (natural gas...propane installation will require storage tank lease costs) amounted to ~ $ 7.5 k. Smaller capacity generators will cost less but incrementally but IMO size for 100%. The $$ savings are nominal. My total costs included, taxes, installation, inspections, equipment and 5 years warranty by Generac. Don't cheap out on the equipment and installation by downsizing.....you'll regret it later.I’m in need of a Generator due to the FACT that PG&E can’t give me reliable power in Shandon Commiefornia. Anytime there’s a “problem” with power, we lose it. I’ve lost power more times in the last year since we moved here from the Central Valley than I did the last 30 years over there. I’m f’n tired of it. Yesterday we lost power for 8 hours, noon till 8 and that early morning we lost it from 12:30am to 1:00 am.
Been looking at the Predator 9000 since it gets really good reviews. It should be able to power the entire house, or so some videos that I’ve watched, say it can. But if it can’t keep the ac going, that’s fine.
I had an electrician come out and he quoted 12k for a Generac 14k watt installed. After he left, I laughed, loudly, as the generator is 4K so that 8k in parts/labor and NO Permit, 14k with permit.
Looking for some advice on “portable” one that I can put in an enclosure, and a what parts I’ll need to hook it to my panel.
The problem with a gasoline generator is efficiency. I have a 12,000 watt portable gas generator. In 2008 we had an ice storm, I hooked it up and it ran the whole house with an electric water heater. 1gallon per hour, I had a 18hp yanmar 2 cylinder from an APU and swapped them out. Next ice storm it performed perfectly and I got almost 4 hours out of 1 gallon of diesel.Also to the OP - can you even buy a gasoline generator in California anymore???
https://www.washingtonexaminer.com/news/california-law-to-ban-small-off-road-engines
I guess you can...for another 2 years, at least. Jan '24 deadline. Better get one soon!!
Just got the quote…….
$11750.00
