GRINER Trans brake Valvebody?
SUPERSTOCKRACER
4:17 PM
Oblivion
I'm new to the trans break deal and was wondering how do you guys get reverse with a free nuetral Transbreak valve body with a PPP Shifter. I'm running a torqueflite 727 BB trans.
Whats the procedure for getting reverse?
is it push button and lever at the same exact time or is it pull lever in and then hit button or hit button 1st then pull in lever?
heres a better shot of the final installation.
ARC called me directly and said to put in in reverse 1st then hold trans brake button.
The PPP shifter is different, you have to go into nuetral and then pull handle to get reverse detent, I suppose.
PPP is the same, had one in my 63' Start it put it in reverse then hit the trans brake button and hold it down while backing up.
Thanks PoppaJ
think i might need 2 hands to keep it in nuetral.
