Gtx wiring
IrwinTom
New Member
10:31 AM
Frankfort, Indiana
I changed my 1971 lights over to led. I've tried four different led flashers and still can't get the turn signals to flash. They just come on solid light. Does anyone have an idea on what I should next?
Put the stock bulbs back in, it worked great for 52 years until you decided to “upgrade”
Call Super Brite LEDs and give them the original flasher numbers for your car. One for the turn
signals and one for the E-Flashers. They'll fix you up.
i had to get a led flasher with a ground wire to get mine to work. for a test install 1 - 1157 see if they work if so get the led flasher with a ground wire and all will work.
