I have a 500 stroker bracket car,727,4500 stall,etc...the car has a MSD 7AL 3,start button and ign switch, 2 optima batterys in the trunk,36degrees of timing,locked out,1000cfmcarb, 11.5-1compression,all the wiring has been gutted and rewired for racing only.Starting the car cold is usualy pretty good a couple of times, but once it warms up and it gets hot it is very hard to start,almost like the batteries are low or dead(I Recharge between rounds)The charge is good and I am puzzled , has any one have any suggestion for me to try in the off season???Any help is good ,It reallysucks when you are in the staging lanes and your mopar won't start!!!
2 things to check make sure you have a good ground to the motor and check how many volts you are getting when you crank the motor check that at the starter it should be about 10 or better when cranking. I just had a bickel pro stock truck with this problem had 4 volts at the starter when it was cranking it was the main cable put a new one in and it spun like there were no spark plugs in it
