obredneck
So yeah, had to pull a lock the brakes up fast hard stop from about 35 mph and it ended up causing my fan to slam into my radiator gashing into the core and wrecking a fan blade...........I was beyond a little annoyed to say the least.
My concern is that this even happened. I wouldn't think that the engine/trans/etc would be able to move far enough to cause this. Before I climb under the car and tighten motor mounts/k member/trans brackets are there any other things you can think of I should be checking? I know my clearance was a little tight between the fan and radiator, but as far as the blade cut into the radiator there was at least 1-1 1/2" of movement during the stop.
On the plus side, I am now 100% confident in the stopping power on the 4 wheel drums.
Thanks for any help in advance.
