headers help?
headers help
The "Dart" being an "A" body and your Charger being a "B" body along with engine exhaust port differences tells me the answer is: NO
Header compatibility is determined by:
-Engine size & head port size
-Body style
If you want headers for a 1972 "B" body 318 CI or 400 CI you most likely need headers designed for that application.
I'm sure you will get better help than this in this forum but.
Good luck.
It also depends on the brand. Generally they don't interchange but I needed a right side header for a 79 small block Dodge pickup and a buddy had one laying around from a 70 Dart small block. After eye balling them, I gave it a shot. It was close to the frame but it went in.
ok just making sure befor i bid on them they are for small block but i remeber having one header on the car when i got it and the tie rods ran through it weird fit
