Headlight and dash??
STREETREBEL
5:48 PM
Willard,Mo.
I don't have dash lights so I took the dash out to replace the
headlight switch. I guess that is the right thing to do.
Now the really dumb question! ( Does the light switch Knob pull off? )
It doesn't want to come off. Is there a pin or something holding it?
I'm afraid I'll break it if I use pliers, but it won't come off by hand.
1967 Belvedere II.
Alos, my aftermarket oil pressure gauge sprung a leak and sprayed
oil on the back of my dash. Could that have shorted my dash?
Thanks.
The knob and shaft are snap-locked into the headlamp switch, and you can't remove the switch from the dash without removing the knob and shaft.
Disconnect the battery's negative terminal -- you'll be working behind the dash, and when you remove the knob/shaft it will turn on the lights.
The body of the switch has a small round spring-loaded pushbutton on it. It's usually on the bottom, sometimes on the side, occasionally on the top. It's about 3/16" diameter and shaped like a hemisphere. That button has to be pushed and held FIRMLY while with your other hand you tug on the headlamp knob until it comes out of the switch. Somtimes it's a struggle -- keep pulling the knob, wiggling it and the pushbutton until it releases. Once you find the button, it helps a lot if you securely tape a penny to the finger or thumb you'll be using to press it.
Once you've got the knob/shaft out, the switch is held to the dash by a collar nut. There's a special spanner for it, but if you are careful you can use a small screwdriver in the slots, carefully tapped counterclockwise with a hammer until it loosens, then turned by hand. Caution is warranted, otherwise you can slip with the screwdriver and mar the dash.
Oil doesn't cause short circuits.
Thank you very much
P.S.
I took the dash out. It should be easy now.
Should I buy one off of E-Bay?
They don't look the same.
Try for a good quality American- or Canadian-made switch. The ones from parts stores these days are now almost all Chinese. :-( Usually good stock of NOS American switches and such at Old Car Parts Northwest.
