1967 satellite
My 67 satellite headlights do not turn on when I pull the switch, but if I hit the dimmer switch all 4 light up. Any ideas? thanks in advance
Have heard high beam switch will cause this, believe power routes through the dimmer then to head lights and high beam switch if any one of those are shorted would cause similar reaction, will get you the wiring diagram shortly.
http://www.mymopar.com/downloads/1967/67BelvedereA.JPG
http://www.mymopar.com/downloads/1967/67BelvedereB.JPG
Looks like the hot runs through the high beam switch first before going to the headlights so either headlight switch or high beam switch is bad
