heat shrink
bearman
11:29 AM
Phoenix
anybody using heat shrink on the a/c fittings to help seal.
well just worked on a newer model ford and every fitting had heat shrink on it. talked to a rep told me that they are finding that the heat shrink is doing two things. first off tells the tech if a non dealer has messed with it and second makes the system seal prove from those tiny leaks you can never find until enough build up has happened. but by then you have lost most of the freon.
the rep i talked to called it a heat shrink wrap so did some digging and still have not found the true name but i will. but in the meantime also found they are now making water hose clamps that you heat up and they shrink to size.
On what fittings are you referring to? The AC system is already a "sealed unit". So if the flare fittings are not sealing, heat shrink is not REALLY the answer.
And the last thing that you should do is listen to FORD!!!
i agree with you on that but the truth is that trans air has been trying this out for a while now. i believe its more to do with warranty issues more than leak problem. just found it intresting
Water hose heat shrink is way thicker. It does work great.
i understand its thicker just finding it interesting that this high tech comes in so many different ways today.
Gates makes heat shrink tube for radiator hoses, something smaller would probably work on a/c fittings. It seems to hold pressure.
