greg426
New Member
Anyone know what I bought for my 69 gtx 2466330-Id on block
DNRL is under
DNRL is under
That casting number does not look right. Take a better look.Anyone know what I bought for my 69 gtx 2466330-Id on block
DNRL is under
Thanks for input their are no numbers or letters on the flat pad, pulling pan to replace gasket next week will look , no other numbers or lettersMore info would help.
Partial Vin code from the pad just above the oilpan rail. (Vin should tell us what year and assembly plant.)
Numbers and letters from the flat pad next to the distributor (assuming a rb block)
D/N is just an indicator of which shift cast the block.
And, I can't find that casting number either. Does it say 440 after the casting number?
