68suprB
68 super bee 4 spd
383 bored .30 0ver
Pertronix Electronic Conversion
Comp Cam 292 duration .501 lift
Stock rebuilt Carter 4bbl AVS
New fuel line from tank to carb
If the car sits 1+ days or so, gas pedal has to be pumped 10-15 times, then motor will fire up, run for 2 minutes or so at idle and stall, then secondaries must be held open manually while cranking to get it to start again.
Today I pulled the carb off and completely tore it down, cleaned and re-assembled it (all gaskets ok). Car started up with a little hesitation, idled for 15 minutes then i drove it 10 miles with absolutely no issues, didn't stumble, stall, etc...good power and ran perfectly fine. After parking it I let it sit 20 mins....nothing. Starter is engaging, but motor will not start no matter what, even tried starting fluid with no luck. Here's what I'm thinking:
1) Somehow the carb is the issue
2) I could see air bubbles coming into the fuel filter from underneath (filter is directly under fuel pump) and the fuel gradually drains back out of the filter the longer it sits. I would think this would be an issue after sitting for several days because it would be sucking only air in for a few seconds until the pump can pull the fuel back up to the carb, but not after running for 20 mins and only sitting for 5 minutes
3)along the same lines- maybe a pinhole in the gas tank somewhere? Fuel line is totally new from the gas tank to the carb, but if the air is being introduced before the fuel pump, it must be the gas tank?
Thanks guys
383 bored .30 0ver
Thanks guys
