steve from staten island
- 12:44 PM
- Sep 24, 2012
- staten island,ny
My 383 is out of the car on a stand and I'm having some issue's with it. I had it running after some ignition problems but I'm not sure if the firing order is correct or a carb issue. The carb was rebuilt by a shop that does only carb rebuilding. I have a petronix 2 ignitor and coil. I had the #1 piston at TDC,timing mark at 0. The vacuum advance was pointing toward the drivers fender. I started with #1 wire were the rotor was pointing. Still hard to start won't idle. When i checked it again it seemed the rotor was off slightly from were #1 was at. I moved each plug wire over one spot and this helped but not enough. Can the rotor stop in-between the towers on the cap,so that its in-between 1 and 8? Is this possible? I also notice when it was running and i moved the distributor i did not see any change. In addition when it does start it will only start with the distributor in a set spot. Please bare with me i know this hard to understand and I'm having trouble properly explaining it but I'm trying the best i can. Any advise is appreciated ---------Thanks
