g413
I'm replacing the original Carter 4 BBL with a new Holley Ultra Street avenger on my 96 Plymouth. The car has a 383 with an auto transmission. The mechanic thinks I need an additional linkage mounting kit. OK, but I'm not sure what to get -- so many little kits and brackets are available. I guess the throttle and the auto trans need to connect. Is it obvious what I need?
Question 2. I know he is probably going to try to connection the coil ignition source to the electric choke -- but Holley says this is not correct due to reduced voltage to the coil.
So where should the 12 volt source be connected to once the ignition switch is turned on?
