eagleone1983
I don't know why I've never checked this before but I did the paperclip test on my Holley 770 Street Avenger and the secondaries aren't opening. I'm actually happy they aren't because I've always felt that there should be more power to this car with all the add ons I have on the engine. So now I know where the power is hiding since I'm basically running a 2-barrel. I've done some googling and saw some things to check but I'm a carb dummy and don't know where the vaccum lines are that actuate the secondaries to verify they are clear of obstructions but here is what I've done so far...
- Verified the secondaires open manually when the primaries are held open, check. There is also a sort of sucking sound coming from the carb when I do this and when I let go of the secondaries they close slowly
-Verified the throttle cable adjustment is opening fully, check and double check
-Carb initially had a plain spring in it so I changed to a yellow spring (not the short one) still no worky
So that's what I've done so far and now some info about the engine/car. '69 Roadrunner Auto, 383 bored .030 over, cam is comp cams XE275HL .525 lift, duration @ .50" 231/237, 440 Source heads, roller rockers, edelbrock performer RPM Intake manifold, Schumaker headers
