4mulas
- 7:47 AM
- Mar 16, 2017
- Just North of Montana
Hi all, thinking very seriously about upgrading to a fuel injection system for all the same reasons most people do- ease of starting, altitude fluctuations, economy etc.... not too concerned if I gain or lose 10-15 horsepower etc.... just want reliability..
I think I am leaning toward the Holley sniper 550-510 (511,516) with a new tank, Holley 19-139 that has the pump in it.
Motor is a 383 30 over with 275 DEH cam. Any recommends as to which brand of EFI and why is also appreciated.
My primary reasons for the EFI are - On occasion I would experience vapour lock and almost always had bad hot starts after the car has sat for more than 10 minutes, cold starts are currently reasonable providing the car hasn’t sat for more than a week. Dang fuel is so cheap these days....when running the carb performs fine but I’m tired of the other issues, enough so to make me contemplate this change.
The large aircleaner base will hide all the EFI well which is appealing to me as my car is near 100% oe correct right now and although that’s not the end all be all for me it’s still kind of important to keep it remaining stock looking if possible..
Questions
- has anyone with a 1969 N96 airgrabber used either one of these systems (sniper or fitech) and does the air cleaner base fit over the throttle body without interfering with anything
- is the over all height once installed the same as the carb so’s not to interfere with the airgrabber above when the hood is closed
- I think they recommend 3/8 fuel lines for supply and return, has anyone or do you think it would be okay to use the existing 5/16” line as a return and install a new 3/8 for the supply? Or even use the exiting 5/16” for supply and install another one for the return.
- is the stock 383 manifold a compatible with the EFI, someone was trying to tell me certain intake runners didn’t do well with EFI, he was a ford guy, so I take everything with a. Grain of salt when it comes from him.. lol.
Any input is appreciated. Thank you!
Questions
