oldbee
Like PR says, I've laughed more than once at YouTube videos of some of the "power shifts" that are shown. Ronnie Sox and others are awful hard to match in that regard and able to do it consistently.
With a history that goes back a long ways as a stick guy, I had got lots of practice on the street before actually getting behind the wheel of a 10 second drag car with a stick that was properly set up. Man, it was a sweet running car too but one thing we NEVER did was side step the clutch pedal. Yeah, even though a slight amount of slip will usually be helpful in many cases with a competition clutch, side stepping isn't the best way to launch a consistent drag car and imo isn't something that's needed doing anyways. With a street car, it usually means broken parts too. And yes, Mr Sox could shift but did he mention side stepping? Never heard it unless he was cracking a joke. Have I ever done it? Yup. It surprised me that it shocked the car so severely (street car) and was somewhat glad that my rpm wasn't very high lol. It might be ok if you have a setup to keep a very slight drag on the drive train to take out all the slack before dumping but...well, why even bother doing that on a street car? The clutch wouldn't last for very long on the street.To me it’s obvious when you watch a car like that.
It’s harder to get the car to a point where you can side step the clutch on the line at around 5k and have that yield a positive result....... one that rivals what a car with an auto and a good converter would put up for a number.
Then, there are 3 shifts to make going down the track....... at high rpm, with a trans that’s often set up less than optimally for power shifting.
And then on top of that, there is a certain amount of skill involved to quickly and efficiently making those 3 shifts....... and it seems that not everyone can do it like Ronnie Sox.
So, the auto car is more or less fool proof.
Stick it in “D” for drag........ mash the throttle and enjoy the ride.
I’m not saying the streeter stick car can’t run the number it “should”...... I’m just saying my observations are that they rarely ever do.
Again, not picking on Al here....... but so far at least, his car falls right into that category(for all 3 of the reasons I mentioned).
Of the runs of his car I’ve seen(and I’m acknowledging there may have been other trips to the track where better results were achieved. I’m basing this off about 1/2 a dozen passes on one day)..... assuming a race weight of around 4000lbs, using the Moroso calculator, the best one I saw shows a number about 150hp lower than 10% off what I’d expect to see for STP power on an engine dyno for his motor combo.
The on track performance is a reflection of the complete package....... not just the engine output.
In this particular application, compared to how the car was being run on the video I saw, there is no doubt in my mind that if you swapped the 4 speed for a nice 727 and a good 9.5” converter the numbers would make it look like the motor picked up 100hp+.
Doesn't running out the back door mean staying in it beyond the finish line? There are no timing lights past the finish line anymore that I know of....PR correct me if I'm wrong,but even with a shitty pass if you run it out the back door you can still figure HP with MPH & weight.
Your wording would be correct,,,,,to the stripe.If my tires spin off the line the MPH only varies maybe 4 or 5 MPH.Doesn't running out the back door mean staying in it beyond the finish line? There are no timing lights past the finish line anymore that I know of....
Ask them how they 'release' please. I'm serious. No one I know that runs a fast stick car side steps the pedal. They release it by letting up as fast as they can. I'll be the first to admit that side stepping does let the clutch engage faster/quicker but it also requires you to bring your foot back over the pedal for the 1-2 shift....unless you are running a clutchless set up......“Side stepping”.....”popping”..... just semantics.
No one I’ve talked to running a Stocker with a stick does anything except release the clutch as fast as they possibly can.
View attachment 921386 View attachment 921387
I agree with Dwayne. When I replaced this converter, I picked up two tenths and two mph in the eighth, compared to when it wasn't broke, obviously .If there are subtle changes from one run to another the ET will change more than the speed.
When the numbers are way way off(as is the case with Al’s car), it’s because the average rate of acceleration for the entire pass is lower than it should be(way lower).
In these situations, IMO, the numbers really aren’t telling you anything except the combo isn’t working.
Sometimes a little common sense must be applied to the results.
I have seen people improve their ET’s and trap speeds dramatically without changing the power output of the motor or the weight of the car.
I’ve seen converter swaps pick up 3mph+.
In a 3800lb car in the 120mph range, that shows a 30hp gain, yet nothing was changed in the motor.
The 3mph came from wasting less, not making more.
The “combination” improved.
That’s part of the value of reliable dyno results.
If you know what the motor makes, and the track numbers are way way off........ you know not to spend a bunch of time and $$$ looking for more power.
In that scenario....... the power isn’t the problem.
It's even worse when done incorrectly lolGotta agree with Dwayne, sticks are violent to every part of a car when launched correctly.
Not so much the autos, but the converters way better!Converters will eat power (mph). So a good one verses a not so good one will show up in the mph. I've seen 3 mph in a 400 hp application. But a manual transmissions doesn't. I've made a lot of passes with a manual, and as long as the shifts are reasonable, mph is always close. The et might change a full second or more due to the launch.
Same with my automatic. I've run back to back runs with the et being different by over one second, but run the exact same mph. Change tire, gear, suspension (not converter) way better et, same mph (maybe less).
I've always been amazed how if nothing is "wrong", make consistent shifts, and you don't mess with the rotational weight, how consistent mph is.
Mopar use to have P/W and W/P tables and showed the manual cars with higher mph than the autos for the same power, but certainly presumed the theoretical best. That was long ago, and autos have gotten better.
I think when SS magazine did the A12 4 speed car tests with Ronnie driving it went almost 111, but 110. and change with an amateur driver.
Just my experience and observation.
Russ, would you expect the trap speed to remain very close if one run was made with a hard launch resulting in a good 60’ time and then have quick power shifts down track......... and another was made with a very soft “walk it out” launch and granny shifts down track?
I wouldn’t, but that’s just my gut feeling.
Be fun to have someone do the test.
For the granny shifts, I think it would be like shorting the track the same distance the car travels between shifts not under power.
