Geoff 2
A lot of misinformation, as usual. You cannot change the dwell of the Chrys elec ign system [ post #18 ].
Low resistance plug wires do NOT automatically make more power. These wires are usually spiral would, a thin wire wound over a ferrite core. The resistance is that of the wire. When metal wire is used, you introduce inductance into the cct, along with capacitance & resistance. I have seen a test of about 10-12 different spark plug leads tested. The leads that made the highest hp did NOT have the lowest resistance.
Below is one reason [ one of many reasons ] why the Chr elec ign is not as good as HEI.
