How Much Does Your B-Body Weigh?
6800, with a reasonable amount of beer, stove fuel, spare oil, tools, camping and fishing gear. The usual stuff.
Water tank full, fridge loaded, 3 batteries total, maybe two jacks, and other stuff.
While going through my old records last night looking for something else, by coincidence I stumbled across my time slips from 1986 for my 67 Charger. I remember weighing it, didn’t remember writing it down. Track scale. Car alone 4260 lbs. All original with AC. Trunk was empty (no spare, Jack, carpet…).
That is surprising.
I could see a Hemi model weighing more but a 383 or 440 automatic model?
So many weights. I forgot about shipping weight. Interesting "footnote":
https://www.hamtramck-historical.com/images/dealerships/SalesmansPocketGuides/1970/70_Charger_1.jpg
3475lbs with Dana, aluminum headed 440/auto, roll cage, full interior w/stock bench seat - minus back seat, fiberglass hood & front bumper w/aluminum brackets. Stock rear bumper, rest of body original steel & all trim present, a/c & heater box removed, all glass, radio (works), wipers (work) Aluminum radiator w/electric fans. Wilwood discs in rear, stock rotors with Wilwood calipers in front. Stock front suspension, Calvert setup in rear, steel driveshaft . . . and I almost forgot the curb feelers and racing decals!
Excuse me for asking, but have you recently removed 200 Lbs? the small print underneath your image reads 3675 Lbs. 3475 is good for such a car and set up.
Dudes that quote these unrealistic weights as gospel have a rude awakening. (Not you, Wayne...I know that you know better)
My "Ginger" '70 Charger was built as a 500 with a 318 and A/C. It tipped the scales at 3660 with the 318. 325 lb difference from the 3335 weight listed above. That was actually without hubcaps and not quite a full tank.
At 6.2 lbs a gallon, a 19 gallon gas tank adds 118 lbs.
Figuring high, oil is about 2 1/2 lbs per quart, 5 quarts adds up to 12 1/2 lbs.
Cooling system, 16 quarts at 2 lbs a quart, 32 lbs.
That adds up to about 153 lbs, still 172 lbs are unaccounted for.
I LOVE that car.
66 and 67 non-Charger B body cars are light compared to later B body cars.
I LOVE that car.
I would guess being that the '66 and '67 Bel's and Nets share pretty much most of the front mug sheet metal and chassis with the Chargers, that that's not a factor at all.
Where the Chargers weight faults haunt the design, is from the door/roofline/rear quarter sail panels and back, where the Chargers look to be burdened with a lot of weight. Probably the lightest part is the deck lid itself.
Am I correct?
Agreed, the '66's and '67's are handsome cars.
Roof/C pillar in general is drastically different between 66/67 and 68-70.
So is the floor and gas tank.
I'm not sure what specifically it is, just that I have owned many 66/67 cars and they drive light and even push light compared to the two 70's I've owned and many other 68-70's I've been around as well as the 71-74 cars I've owned and been around.
If pushing a light car around is hard, does it make sense that perhaps there is a drag coming from either the transmission itself or the rear differential?
All the A/C junk has to add up too?
Am I correct?
The whole front grille and trim assembly , and taillight assembly probably add almost 100lbs over a 'Net
This is true, my car is very easy to push around.
That is surprising.
Fastback’s weigh more that coupes in general. Also the folding seat mechanism add weight. 66-72 hidden headlight gear weighs more. And 66-67 is pot metal stuff vs 68-70 plastic. Larger rear glass weighs more. Fastbacks rear cargo area has covers that add. I’d think a 66-67 Hemi Charger has got to be the heaviest B.
Pre-67 B-body consoles are made of way heavier material.
This thread inspired me to return to the scales where I've been weighing my cars.
Today, as ready for the street with all equipment in place including spare tire and about 20 lbs of jack-tools-ignition parts....
3940.
As I stated earlier, the place I use only breaks down to 20 lb increments and rounds UP so I am between 3921 and 3940.
Did I electronic scale your car before at Willow before? I did a bunch up there.
Not a B-body
68 Barracuda S coupe
-aluminum: heads, intake, water pump, radiator, master cly
-P/S, auto, man disc/drum
-console,
-aftermarket:buckets, steering wheel
-1.14" torsion bars, Hotchkis TVS with subframe connectors
-TTI headers w/full exhaust and tips
-15x8 steel spare
-3/4 tank gas
3209 lbs
Currently my B body is pretty light... I'd guess around 1000-1200 lbs.... But that number is likely to increase in the future....
My 67 Belvedere small block 4 speed was about 3650lbs. With front sway bar, torque boxes and frame connectors.
