How to create a hologram a real hologram
XEO1-
2:12 AM
Memphis
John carpenters Escape from LA…
at the end where the hologram is of plissken within a 2 mile radius.
the camera reads the gusts of winds(turbine fans around the physical body trigonometry around his body like waves north hitting south and south hitting north’s canyon inbetween two bodies of water like most of Florida is with water on both sides..
Then you take wind touch pad around the body to produce the shadow of the person on the other side of thr camera..
The persons physical body is inbetween thr gusts of wind letting the camera see the animate object moving legs and arms to send to the other camera within a 2 mile radius.
The shadow reads on the other side(the hologram) like a slinky and it comes from the eclipsing physical body shadow.
The shadow is within a capsule that wheee the slinky shadow is read-like a ship within a bottle artistically screated by drawing the wing gusts physical form within the capsule to walk around….
so all it is is a shadow within a clear capsule like a tube-or Star Wars saber-but it controls the light to make a ball or other object inside thr clear capsule for someone to draw thr shadow…
like that and the shadow is read from the lights shadow of the person walking from the other side…
Like this |->-<-|
The shadow of the person is configured by wind pressure to produce a object that someone needs to draw…
It’s still not a true hologram but it’s as close as I can make of one…
Or you can have a pressure suit!!!!!!! Ah man I forgot about my other ideal…..
The pressure reads all makes of clothing apparel so it can sense via pressure what’s Nike or down to a select nike brand to make it easier to only draw thr face of the person on the other side…
I forgot the capsule works off of water and clear oil where the shadow is at compressd because oil negative is water..
You can tell oil and water doesn’t mix well-water bubbles up on top of it…..
The hologram is being created by electric conduction through oil and water that’s reading the shadows waves inside the slanky shadow where the springs ///// is every animate of thr shadow within the 3D capsule that it’s image trigonometry depicts it….
The wind gusts are showing thr epectric clear oil what to produce like neurons working to move the fingers to type letters to produce a action…
Like a complete muscle system the water is around the clear oil…. Like tendons working in muscles.
But closest I can get is water pressures… so it sucks right now but I’ll get closer….
The clear oil is where the shadows being created by exterior forces(water working pressures all around the clear oil… the clear oil is the holograms physical eclipsing of thr shadow that is being created by a pressure suit like this. |->-<-|
