How would u know what heads came with ur engine from the factory
Mikey59
Cottage hills Illinois
Is there different heads that came with 440 six pack are a 440 with a 4 barrel on it . Would it have bigger valves on the six pack over the 4 barrel ? And how would u tell the difference between the two . One would think that the six pack would have bigger valves than the 4 barrel. R there numbers on the heads to tell them apart? And some one had gave me a gift and I wanted to thank them .
Same heads within the same model year. Only difference from a 383 2bbl to a 440+6 is the valves & springs. Same exact head casting. Same valve size.
69-70 2843906
1971 3462346
So with this 440 beening a 1970 it should b 906. Where would the stamping b located at ? Under the valve covers ?
yep, under the valve covers. They could also be 452’s which are the same as 906’s but have hardened seats.They would’ve been changed tho, as 452 didn’t come out until 1973 I believe, but a popular change to get the hardened seats for unleaded has. Other possible heads are 516, 915, 346, and 250, which are all direct bolt on’s but have different sized valves and chamber designs.
Yes, the casting number is on top of the intake port. The '69 & 70 6 Pak motors will have 906 heads. My recollection is that the '71 6 Pak's may have had 906 or maybe 346,in a a few most likely 906. Valve size is the same.
You can fully spell out all your words. You are not charged by the letter here!
:bananadance:
:bananadance:
Agreed. Along with proper sentence structure, why is it that two extra letters to complete the words "your", "you" and "are" that big of a burden to type for the younger generation?
The 452 heads have the hardened seats from the factory but if they are machined later on there goes the hardness :)
A follow up question, i thought the hardening was an "electro heat treating" which I didn't think was surface hardening, true or?
My machinist says the early years they were just “flame hardened” which is very thin.
:bananadance:
Younger? I have a few relatives in their 70’s that do this when they text.
I wonder how they would do that on a production line. I'm not challenging that, but seems difficult.
Also wonder how much durability was really lost with the elimination of lead? Maybe at 30-50K miles would show up. Just curious if there is any actual data on that.
1964-67. #516
1967. #915 440HP
1968-70. #906
1971. #341
1972-3. #345
1973. #213 Motor home
1974. #902
1975. #975
1976-78. #452
The 975 and 452 heads have flame headered seats. No factory BB head had true hardened seats.
1967. #915 440HP
1968-70. #906
1971. #341
1972-3. #345
1974. #902
1975. #975
1976-78. #452
‘67 #915 440 & 440HP.
The 915 was made with both size exhaust valves all year.
