BSB67
BSB67 awesome info! Actually Dave also recommended the SEH3642BL cam as well as a smaller choice. He gave me two options. I see the smaller of the two is good at 3000RPM an the bigger is 3500RPM. I just don't want to overcam the engine and be disappointed. Idle I want choppy but I need vacuum for the brakes. That is what makes me lean towards the 238 duration with a 110 degree lobe separation. I have also been told to bump the cam up by a couple sizes with the stroker as it will eat up some duration. I basically want a nice sounding street engine that doesn't idle like an RV like mine does now. The cam is so small it has almost zero chop to it. As long as it makes vacuum for the brakes, the rest is easily manageable with the 4 speed and a 3.55 gear in the rear. I am leaning towards that K60 grind with a 110 lobe separation. The smaller ramps in Chris's cam with less lift will be a little more forgiving to my valvetrain. UNless you think the 244 degrees of duration will be eaten up with the stroker by that much? The car is all stock weight and has 10.75:1 compression with eddy rpm performer heads, performer rpm manifold, 850 quick fuel w/ mechanical secondaries, and a 440 source 500" stroker rotating assembly. I have a 28" tall rear tire on it, so with 3.55's it will be right about 3000RPM at 70MPH. I do have a 3.23 sure grip center section here that I could throw in, but I think that drops me out of the power band I want around town to have fun with.
Don't hold on too tight to what the literature says about motor specs per cam. Its a rough guideline. The literature does not know if you have a 361 B motor, or a 500+ RB motor. My cam is in the range you're talking about, has a 3.23 with a stock converter, no part throttle kick down, and drives through the neighborhood at 1100 rpm in third gear nicely. Plus, your 4 speed give you a lot of driving flexibility.
And the 238° will definitely work well too.
