Hy-Lift Johson Variable Duration Lifters - Do they work?
Road Grabber
2:40 AM
Sarasota Florida/NY State
I am planning a build sheet to include a "Hot Street" Hughes cam SEH2832BL-10 in a 440-6 pack engine with 10.25 to 1 pistons with the closed chamber 240 Trickflow heads. I am currently able to use my power brakes with 11 vacuum using the existing purple shaft .284/.484 cam.
The Johnson lifters boast increasing idle characteristics and bottom end torque. Relying on oil pressure to properly manage performance seems a bit unreliable and too good to be true.
Does anyone have any experience with these variable duration lifters?
Hughes also offers a "tight" lifter that react faster?
I also use Rhodes lifters in my 66 427 Vette.
Have been in there for 5 yrs.no problems.
We also use rhoades. Not a big fan of the original non adjustable rhoads and sewing machine noise they make. We installed the rhoads vmax that you can adjust how much they work. You have the option of zero lash and they will do nothing if you hate the sound they make. Vmax act like a solid cam on the top end because they are fully pumped up, we ran about .010 lash and most of the sewing machine noise goes away but noticable more torque.
Another company makes the lifter bodies for Rhoads, I think it may be johnson....?
Everyone has copied rhoads design. When you call rhoads good chance you'll talk to the son of the original inventor, his name is Jack Rhoads. :thumbsup:
Johnson and Hi lift Johnson are two different lifter companies. Rhoads use Hi lift Johnson’s to source their lifters. The original Rhoads and the Hi lift Johnson’s 5003’s are similar. The 5003’s IRC may not bleed off as much duration. I do not recall if the 5003 has a oiling grove option on the lifter either. The option to tailor the engines low rpm characteristics with bigger cams with the Rhoads Vmax and Vpro’s is cool. Super lube option is cheap insurance. The v series lifter pump up and act close to a solid cam on the top end. Probably similar to that 5003s. Never been around the 5003s lifters to say how they perform.
x2 on avmax style lifter crower also has them
that's a LOT of spring presure
x ref to the howard catalog or lobe catalog and see what howad recommends
find out wha the durations 2,006 and .200 are
run the stiffest pushrods you can fit
use the b3 racing industries kit- did you read his three tech reports
use viton seals when you cut your guides for dual springs
do yu have light valves
Hughes also offers a "tight" lifter that react faster?View attachment 940900
Personally, I think that cam is fine as-is for your setup. Aluminum heads with better port flow usually work well with more lobe separation than factory iron heads, so why not get Hughes to grind it on a 112-114*LSA if you are needing more vacuum or smoother idle? If you have to try the variable-duration/ Rhoads-bleed thing, get one size larger Hughes cam with the wider LSA. Hughes will do that for a small fee. A B motor with a short 3.38" stroke and your compression ratio would be more suited to the size setup you are contemplating, IMO. The Rhoads original and Crane "HI-Intensity" lifters do work, and the Crane are pretty quiet. My favorite are the V-MAX Rhoads, that adjust off the BOTTOM of plunger travel. Almost unlimited RPM potential (as stated earlier), like a solid cam.
My point is: your cam is really too small for variable duration lifters in a flat-top piston (10:1 actual) 3.75" stroke motor.
I think that cam is really to small to need a variable duration lifter also. The faster the ramp the less effective the variable duration effect is. The Hughes cams have a pretty aggressive ramp, really do not need the variable duration on a cam that size with any sort of decent compression.
But, we (curiousyellow71) and I, run vmax or vpro superlube lifters on hft cams when ever we can if the engine has an adjustable valve terrain. There are benefits to them beyond the variable duration feature.
Jones cams did some testing with the Rhoads vmaxs a while back and was impressed how they held on to the high end power. That is saying something, those guys are not easy to impress.
How is 96mph in the 1/8mi with a cast (H405CP Sealed Power) pistoned 367" (.040"over) sound? Using a .508" Comp Purple Plus cam and V-Max lifters with 273 rockers that's what we did years ago. 7000+rpm!! THEY WORK!
Thanks for the advice and experience from all of you. I appreciate all the input. Sometimes we over think when starting over. For me it's because these cams are a new breed compared to older Direct Connection..showing my age...cams. If the cam doesn't really push the need for the variable lifters I will stay with the 5003s "stiiff" lifters that are supposed to work well with the Hughes "designed for Mopar" cams. I was impressed with their cam comparison article. Howards was very close to their performance as well.
I have considered the hydraulic roller lifters. When I read about the hydraulic rollers they sound nice but I wonder about the cost justification. Hughes said that both their flat tappet and hydraulic roller cams perform about the same but the rollers last much longer. I don't know if I will have to worry about being around for an extra 100,000 miles in a car the gets driven only a couple thousand miles a year so adding intermediate gears, pump shaft, cam button, expensive roller hydraulic lifters is a big cut in the wallet.
I enjoy the lumpy sound the current cam has now with 11 vacuum. No one seems to provide vacuum specs with dynos. It would help those who want to keep the power brakes working without adding canisters or whatever.
great idea thanks
Every setup has it's drawbacks, rollers included. Use a good break-in oil and follow the proper procedure, get your preload setup right and you'll be good to go. As far as vacuum specs, they can't really say because the vacuum you get is so dependent on how it's tuned, the valve and piston ring seal, etc..I've seen on here where guys with the same cam as me get 10-11" when I'm getting 13-14".
100% correct. I know it's legendary for being street-friendly, but way back in the 90s when I built my first street/strip 360 (I was always big blocks or stockish 318s before that), I used the .528" Purple Shaft solid and got 16" vacuum. Musta got lucky-lol. People couldn't believe I had a mechanical cam, besides the rocker clatter. That was with .028/.032" valve lash and 1.5 Erson iron rockers. With 1.6 Crane roller rockers and .022/.024" hot lash it still had 14"hg. Then with a brand-X 383 stroker I couldn't get 10"hg with a 230-something hydraulic roller with a 112*LSA. Go figure!!
I disagree to a point. Let’s start with a better choice in cams for the drive train at hand. Which is what after the engine size?
So far, that is all we have. I’d like to know the car weight, transmission in use, gear ratio and tire size.
While the engine is big enough to make the power to easily push the car, is this a 4 spd or auto with what converter? Also, can the converter handle the larger duration camshaft without ill effects? Is the gear ratio numerically high enough to provide enough torque multiplication to move the car weight and stock stall converter?
Your assumption of the cam not needing or actually making good use of the variable duration lifter is reaching a bit far IMO.
For example only......
If the Rhodes (basic) lifters provide there maximum 20* duration cut, the 228*’s of duration turns into a 208* duration cam which will work excellent with a stock trans/converter/2.76 geared rear.
@Bighead440 , the deleted portion of your post I like.
@Dodge Bros , be it a fast rate ramp cam or not, (which I like the faster rate myself,) any cam will benefit from the variable duration lifter if the intent is geared to what there for. A faster lift ramp rate am will show the exact same effects no less than any other cam would. To say otherwise is ignorant and blind.
Again gents, the rest of the combo is missing and I think it needs to be known.
I think (from some experience) that even with aluminum heads and quench he's going to have adequate cylinder pressure without any bleed-off of duration with that camshaft. He could always add them later as a crutch, if needed. This is coming from a guy (me) who has run stupid combos in the past (learning), like a '75 Imperial 440 (7.?:1 stock) with 915 big valve heads (quench? HAHA) and a Crane 302/312* Commander hydraulic cam with Hi-Intensity lifters in a '76 Plymouth GranFury Custom Suburban wagon (factory 400HP!!) running 3.21 SG gears weighing 5300lb with me in it. Using a stock '71 Road Runner 11" converter, it flashed to almost 3000rpm from the weight and torque on a dragstrip launch. No spark rattle, but without an external trans cooler she would boil the trans fluid right out of the bellhousing (vent) on a 99 degree day with 5 passengers on board, from the stall effect of just cruising the interstate. (Ask me how I know!-LOL)
Gotcha. I as well have run the Rhodes on several engines with out of balance combos. I am not a stranger to these lifters.
I run my small blocks @ 11-1 with aluminum heads and cams as small as a Hyd. roller cam, 224@.050. 93 Pump gas all day long. Stock roller tappets.
