feeling defeated ? well, my story!
6 and a half years with my car on body shop and still on jackstands, half primered at this moment
Engine dissasembled, trying to correct the earlier bad deck jobs, allways slanted! 3rd try at diff machine job, once again deck slanted, on the opposite direction. 4th try at diff machine shop and finally decked flat... but now pistons leaves the bore around 0.040" ( they were leaving barelly 0.010 the max due the slant cut... how did you reach 0.040" ? ) so my matching numbers engine is ruined!... working on a diff block now which will need to be bored 0.040". Advantage is has being never decked ( mine was decked the first time because block was sleeved ). Will they be able to CORRECTLY deck it at 9.98"... dunno. 3 years on this deal!!! JUST TO DECK IT!!! the 3rd machine shop also broken a piston skirt!!! niiice!!! and nobody is responsable for this. Doesn't matter anymore because had to get new pistons on new bore anyway... but at my expenses everything.
2 years trying to reproduce te Rallye multicolored stripe ( I have a NOS one as a sample ). Bought the reflective vinyl ( 3M ). Had to go to Spain for personal reasons... came back and nothing was done because they needed me!!! why you needed me? is not my job!!! so finally decided, FORGET about the multicolored strip, cut my vinyl and will make them white reflective again!!! the plotter made wrong cuts, overlapping one over the other. But you know what? it seems was my fault! because blah blah blah... so left the designer shop with the bad cut material and nothing in hands.
being defeated... yes I know what is that!!!
