texas69bee
Yeah I went up to just before TDC with the stop and used the hole on the metal as the mark spot, then around the other direction until I hit again and the split the difference, made the mark in between and used that as zero on the tape. I just don't get it
Edit...
On your tab there is a hole, when you go one way with your stop, use a felt tip marker to put a dot on the balancer, go the other way, put a mark on the balancer, in between the 2 marks is TDC.
