Ignition light
Bird 426
1:01 PM
Illinois
Can someone tell me on a '69 Road Runner, I have a hole above the ignition switch, anyone know about this light? Least I figure it's for a light. Must be a metal casing twist in bulb? Go through a relay somewhere, probably a momentary light just for key into ignition?
I have looked through my FSM and can not find it, well, in accy I found one for a Dart, didn't think the Dart even had one in '69.
You are correct. It is for a courtesy ignition lamp, it is retained by the lock cylinder and sandwiches in between the dash and the lock cylinder.
Okay, confirmed. Now I need to find all of it!
Thank you.!
Update, went down to place an ad to look for this courtesy light and relay or timer and saw another post. It had a picture of the relay, I remembered seeing one when I was digging around with a mirror to look at the socket for the lamp. The whole thing is there , but not plugged in. The lamp was hiding behind a loom. So I have all of it! This is great!
Thanks again!
