I ran Crane golds on my stroker which are unbushed, and never a problem. I did buy a set of those stainless rockers a long time ago, and sent them back due to poor quality, pit marks on the rollers.
hughs engines =melonized steel gear on a billet roller , been running one for about 13ish yrs, ...They make cast iron roller cams? How do they hold up to the steel roller lifters? It would def solve the distributor drive gear issue.
Hughes does their own cams or are they rebranded from another manufacturer? As that is the route I want to gohughs engines =melonized steel gear on a billet roller , been running one for about 13ish yrs, ...
I believe Hughes cams have been custom grinds from Howards for a while now. You should be able to call howards direct and get the same grind off their .904 lobe list. Hughes has never ground cams that I know of and has always ordered them from a cam grinder.Hughes does their own cams or are they rebranded from another manufacturer? As that is the route I want to go
I am a bullet cams dealer and do a lot of custom spec cams. Do you know if Howards offers the iron distributor gear option on their roller cams? I am building a very mild street cruiser and want the reliability of a hydraulic roller but don't want to use a bronze geared oil pump drive. Thanks!I believe Hughes cams have been custom grinds from Howards for a while now. You should be able to call howards direct and get the same grind off their .904 lobe list. Hughes has never ground cams that I know of and has always ordered them from a cam grinder.
I don't think we have run a Hughes cam, but we currently have a roller cam from Howards. Overall, I prefer the custom Bullet cams we've run. I'm also not a fan of the limited informatiom on the lobe profiles at Hughes. Howards has all the durations listed which I prefer.
Yes Howards does at least for HR cams, I think its called the everwear gear, and you can run the stock oil pump gear. Ours is actually the Trick Flow hr cam made by howards, we have a stock distributor gear. Being able to use the stock gear is a nice economy feature over a billet roller cam. I wish Bullet offered it.I am a bullet cams dealer and do a lot of custom spec cams. Do you know if Howards offers the iron distributor gear option on their roller cams? I am building a very mild street cruiser and want the reliability of a hydraulic roller but don't want to use a bronze geared oil pump drive. Thanks!
I spoke with Bullet today at PRI and they have a steel gear for the BB intermediate shaft, so I am going that route since I am familiar with their cam lobe profiles.Yes Howards does at least for HR cams, I think its called the everwear gear, and you can run the stock oil pump gear. Ours is actually the Trick Flow hr cam made by howards, we have a stock distributor gear. Being able to use the stock gear is a nice economy feature over a billet roller cam. I wish Bullet offered it.
I wasnt aware of that but my brother said Bullet has had that available for a long time... but we haven't done it because the Howards cost a lot less. So report back..it will be interesting to see if that is still the case. The Bullet roller cams we have run much quieter then the howards.I spoke with Bullet today at PRI and they have a steel gear for the BB intermediate shaft, so I am going that route since I am familiar with their cam lobe profiles.
I will do that. Hawk and I were discussing this subject Thursday night. I had no idea the gear would press off of the driveshaft portion.I wasnt aware of that but my brother said Bullet has had that available for a long time... but we haven't done it because the Howards cost a lot less. So report back..it will be interesting to see if that is still the case. The Bullet roller cams we have run much quieter then the howards.
Who's hydraulic roller lifters have you used with success?
It would be interesting to have comparative dyno charts to see how each stacks up.
Wonder what that would be like dumping the clutch?With the hub dyno, you can make a full rip right off the trans brake through all the gears simulating a quarter mile pass. If you’re just looking for peak power and the curve information, you’ll get it into high gear and hit it which is what you’re seeing.
If you take the time to set up the cams in a block you can compare duration at 0.200, 0.300, 0.400 etc. You'll quickly find out that roller cams keep the valve open for more time than a flat tappet cam. I don't know any cam company that publishes area under the curve but the number should be available to them. It isn't easy to solve with math, but it can be solved graphically without too much work.I agree.
Forgive my lack of experience on this, I'm sure it shows in how I express myself in this matter.
The flat tappet there does have less overall lift @ just .528 compared to around .544 but that is so small, I doubt anyone can notice.
The roller lobes look sort of like an oval while the flat tappet ones look like eggs. I'm used to hearing of duration measured with the lobes .006 off the base circle, .050 and recently, .200.
This is interesting and does seem to answer my question about comparing that "area under the curve". I'm tempted to actually run the car on a dyno with the existing cam and then with the roller cam to compare the power curves. Dwayne estimated that it will peak below 6000 rpms, likely around 5500-5600 I recall.
Did you make a choice on the timing cover? I read most of the thread but never saw you mention my billet cover. The billet cover costs a bunch, but it solves a lot of those issues. I include a plate that allows you to measure the backlash. The timing cover gasket makes a big difference so you have to be careful about which gasket you use.Since I've never installed a roller cam in an engine that wasn't built with one, I still wonder about how all this will work.
The concept of the back side of the camshaft sprocket riding against the block seems weird even with a Torrington bearing. I haven't looked into how the cam button is modified for the required fore/aft limits of the camshaft. The limit that I read was .010 of an inch fore/aft. That confuses me, since the lobes in a roller cam are not tapered, the roller wheels on the lifters seem like they'd be fine with the wheel hanging off the edges a little. I'm just curious as to why they are supposed to restrict the fore/aft movement so much.
Back to the clearancing of the cam button....
I may buy a reinforced timing cover or weld a plate over mine. That makes sense.
Regarding the cam thrust button....
Let me guess....You must first measure the depth of the timing cover and gasket, then measure how far out the cam button sits out from the face of the block.....then somehow mill down the cam button to get to a number that is less than the depth of the timing cover by no more than .010.
I'm supposed to use a straightedge and plane across a tiny cam button to the face of the block? How is that done with accuracy?
