Initial Steering Set Up
Moparfiend
5:58 PM
HOT
Ok I am now at the point of assembling my steering Center link. And attaching the tie rods/pitman/idler aems.
Looking at the FSM I didn’t find the part about centering up the steering gear/Pitman Arm initially.
I assume I need to center the Pitman to the box to give me equal Left Right range. Just trying to figure out how to clock it. Also I suppose the Idler also needs this as well?
Thank you in advance for your help on this.
The pitman arm only fits 4 ways, three of them put the arm in a position that absolutely will not work. Realistically, there is only one right way it goes on.
Look close. There are 4 flat spots 90 degrees apart. You would have to be really drunk to install it wrong.
Thanks KD. Do I need to find the “high spot” of the gear box for centering?
On stock steering boxes, there is a flat spot at 12:00 when the guts of the box are centered.
With the Borgeson, you have to either rotate it full left then right to establish center or use a torque wrench to find the point with the highest torque resistance. Screw that....I just rotated the input shaft back and forth and counted the turns. I marked 12:00 with a paint pen.
Again, the stock steering box has a flat spot here and the coupler is matched to fit that.
What he said. I did the turn and divide too.
That’s a center link, not a drag link.
They are not the same thing.
