install dodge letters on hood.
charger10
4:25 AM
idaho
i bought new letters for hood '67 charger a number of years ago. don't know how to put them on.
there is a plastic sleeve on tips. does it stay on or not? if it stays on i will have to drill holes bigger.
if it comes off do i fasten letters on with push nuts? no threads on points.
The sleeves get tossed.
Wax the area before installing.
You need speed nuts like the one shown.
They cut a little groove by themselves.
Make sure they have the correct inside diameter.
Carefully try a couple on in your hand before trying a letter on the hood.
Use a nut driver and not real tight.
It's not tough just take your time.
Don is spot on.....
Double check the self tap nuts.
" Make sure they have the correct inside diameter. "
Those nuts are available from NAPA in various sizes.
Boy, you Dodge owners have it so easy! We Plymouth owners have 3 more letters to install.
Mike
I would run the speed nuts on and off once before installing. It’s less frustrating than finding out in the middle of installing them in tight spaces that a speed nut is too big but won’t back off, or not correctly cutting threads on the stud.
thank you very much. sure appreciate you guys.
bruce
Also, those are 66 letters.
