Installing a Carter Pump
RDC5
2:42 PM
Ontario, Canada
I am installing a Carter electric pump on my car, what kind of relay should I install? The ones I've seen are for 30 or 40 amp draw pumps and the info on this pump says it draws 4.5 amps, what relay should I use? Its a 8 psi pump. Thanks
A 15 amp relay should work fine. You will need to install a pressure regulator and set it at 5 psi if you are running a carb.
The standard relay at places like Napa is 30 Amps, and that is plenty sufficient. You can always wire the pump off the car and test amperage draw if you are really concerned. Like @toolmanmike said, if you're using a carb, check your pressure. I have inline fuel pressure gauges installed on both of my 440's to ensure the pressure is correct.
Thank for the replies, I just ordered a 30 amp relay. Already have a regulator and gauge to install as well
The rating of the components can always exceed the expected amperage...but never should the expected amperage exceed the rating of any one component!
