Installing pedal assembly in 64 Plymouth question/help.
64SF
2:09 PM
Ocala,Florida
I'm doing a 4 speed conversion to my 64 Sport Fury and need some direction on the pedal(s) replacement. I have a complete brake/clutch assembly ready to go.
Does the dash need to be removed? Any suggestions/thoughts/directions would be appreciated.
No! it can be installed without removing the dash. Removing the steering column will make the job easier though!
I check under the dash on my 64 with the 3 speed. It looks like the clutch pedal bracket just bolts to the left side of the brake pedal bracket. I dont think you need to remove that bracket only add the new clutch pedal bracket. The pedal pivot bolt is in the same place only longer for both pedals.
