And So It Begins - Tremec TKX Conversion Into A 64 Polara
The engine/trans will be test fit this weekend and I'll find out. SST sent me the trans with rear shifter position along with a shifter and instructions for installing in the front position. The neutral safety sw doesn't work in the front shifter position.
Different cars will have different shifter locations. What car do you have? In regards to the neutral switch, you are correct that the forward mount does not have one, but that's easy to overcome. I just mounted a brake light switch to the clutch pedal. If you have an early B body, the rear shifter position will likely not work very well.
