Mr Gorsky
Hi gents, hoping someone has come across this before.
I have a '72 Satellite 318 auto with the factory electronic ignition and the car has developed an intermittent ignition problem. It will start from cold and run perfectly for a while (up to 30 minutes), and will then die and refuse to restart.
I've changed the ignition box twice (ensuring it has a good earth), put in a new MP distributor (incl rotor and cap), fitted eight new NGK plugs, fitted new ignition leads, replaced the dual ballast resistor twice, replaced the coil, replaced the ignition switch and manipulated the wiring while it's running to try and find a fault, but with no joy.
The car has had a chequered history with wiring work done prior to my ownership. It has had the black alternator output wire bulkhead pin burn out (as commonly occurs), and this has been bypassed with power running directly from the alternator to the starter relay stud. As a result, the ammeter reads incorrectly with just the one red wire feed going through the bulkhead, with the black wire from the ammeter continuing to power the welded splice and all the loads as per normal.
There is one odd thing that may be significant, but I'm not sure. Whilst fault finding, a second distributor was electrically connected and spun by hand with the ignition switch on and the coil lead output showed a good spark to earth. However, when the car is cranked with all connected normally and the coil lead held near an earth, there is just the one good spark immediately after cranking begins, then nothing. It's as if something is dragging down the ignition circuit.
I have ordered a new engine harness and hope to have that in the next week, the engine bay wiring is pretty ugly as can be expected on a forty year old car.
Cheers,
Mr G.
Oh, I should add that I've disconnected the bulkhead connectors and cleaned them of corrosion and sprayed them with contact cleaner...they seem ok.
Had them on and off a few times.
Cheers,
Mr G.
