mopar 3 B
Log chain, steel plate and hydraulic jack will also put them on. Safe maybe not but it worked.
Red neck but it works, cut the old outer race with a cut off disc in a die grinder, remove the rollers, cut almost through the inner race and split it off the axle with a chisel in the groove you cut. To install, raise the flange end off the floor woth a piece of wood so you don't drive the wheel studs out and drive the bearing and retainer on with a piece of tubing or exhaust pipe and a hammer. Get a piece just bigger than the axle so it drives off the inner race.
to make it easier but axle in freezer and bearing in oven at 200 f
and keep tapping to keep tight till it equalizes in temp after install
