Is this a cast or forged crank?
Moparfiend
10:35 AM
HOT
From my 1970 318 original motor in the sport satellite. Looks forged to me but I am no expert.
Is the 318 crank the same as the 340? Same stroke?
Thanks,
Ron
I
did what am I missing?
Look at the very narrow parting line vs the wide parting line. A cast crank is molten metal that is 'poured' into a casting and a forged crank is 'pounded' into a shape. You can also find this process in a YouTube vid on how a forging vs a casting is made. It's well worth looking at!!! I was fortunate to see the process at an early age in real life. It's great to see it in person but seeing it in a vid is good too.
Looks forged to me although 1970 318 cranks were cast.
Found this for what it's worth...
forged crank 318
I think there is some errors on that MP chart. Looking at the 70,71,72 parts book the 318 and 340 took the same internal balancer. Also only 1 crank listed for the 318. In late 72 there is a bulletin on the 340 showing the cast crank and the other external balance components.
It's a forged crank. Just because it's 1970 318 means nothing in 55 years. Anything is possible over that time period.
The factory could have used what they had available on that given day, or someone could have added it years ago. How it really got there is irrelevant.
Put some good aftermarket connecting rods and pistons on and let it eat.
Tom
looks to be a forged crank the one picture shows a wide parting line. If you take the engine apart stand the crank upright and tap with a hammer, if it is forged it will ring like a bell, if it is cast it will just clunk.
Everything I read, said it should be cast. But hearing from other people who broken down bunch of these motors, they said that they found a lot of forged crank in them from the factory. Maybe it was overrun or overstock. But I’m not complaining.
Factory parts book make no reference to the crank being cast. After the 72 year there was lots of cast cranks on all size motors..
I've only pulled a few teens apart that came out of 60's and 70 model cars and only one had a forged crank and that was one from a 67 Coronet 4 dr.
Don’t forget that a 318 forged crank bob weight is way more than a 340 crank. It takes a lot of drilling the counter weights or turning them down to be able to be used in a 340 even with light aftermarket rods and pistons. Kim
Yes I recently read this. It would need rebalancing.
